steering assembly on my m....
Here is what the finished steering assembly lloks like on my M....let me know what you think.....
thanks Kelly
2nd pic I even added a grease fitting like org....lol
Kelly, you may want to consider locking collars on the steering shaft. On a stock m, when pulling the throttle against a stiff gov spring, the steering shaft support will flex backwards. If you have collars on the steering shaft, the support pulls against the steering shaft. This shouldn't allow the steering support to flex back (much).
north puller,
thank you,
yes I put the 2 lock collars back on before welding it completely up.....thank you for the concern....;)
Kelly
Thank You everyone for the welcome backs.....
What u use for motor mounts? U do good work I built my own m brackets n mounts too when we ran a m , I built motor mounts n saved several lbs just neat to see your ideas lee b
Lee,
I have not got that far yet.....I will be probly doing a light weight wide front end that pivots in future along with some other ideas in that part of the tractor as well..... ;)
Kelly
(quoted from post at 19:27:32 02/23/14) Here it is mounted on my M....the throttle just sitting in place not bolted on in pic.....I am making a nice new one anyway.....
Kelly
looks great nice work.
all your parts look great , I have to ask do you pull in stock classes with all these weight reduction parts ?
