John Deere 720 Pistons
58 Deere
I am building a John Deere 720 GAS tractor with a 720 LP parts tractor. Both block have been bored .045 over at one time. I am hoping to use the better of the two blocks without boring again. My question is about using the LP pistons in the Gas tractor. I know this will raise the compression. But how much is too much? I run premium gas in my 620 so that would not be a problem. I just do not want to worry about spark knock. I made a similar mistake with an automotive engine. Or should I just sell the LP pistons? Thanks for the help.
LP pistons give 8:1 Comp and will knock on 87 octane gas when under a good load.
Premium gas (and careful timing settings) should cure that.
I really like to hear a Gas JD Idling with LP pistons..they sound very "Ready to Go"..!
Put an Improved Cam in while it is apart and you will like it even better..
Ron.
(quoted from post at 01:09:47 02/11/14) I agree with Ron
I agree with 730-LP
The cam and followers will be worn. May as well grind them to match the pistons and 91 octane gasoline.
There is power in a good multi angle valve job . Blending the rough edges out of the valve bowls is good too.
(quoted from post at 10:33:46 02/11/14) I plan on having the cam ground. The followers are worn. Who do you recommend? I live in NC.
My experience with a JD A w/power block, stock head with moderate port work I finished up last fall, 8:1 comp ratio with 91 octane knocks like a diesel at idle. Tried retarding the timing as much as 5 deg, but still the same. Haven't taken the time yet to try 93 octane, that may help, but VP Late Model Plus 113 octane cured the knocking. Can't say if the A relates to a 720 or not.
I have a 60 with a Power Block and propane pistons in it. I have plowed with it on hard pulls with 87 octane gas and it does not knock. When I had it apart I was careful to smooth all sharp edges in the combustion chamber. The compression ratio (after a head milling) is somewhere around 9:1. It runs fine with no detonation whatsoever with timing slightly advanced from stock. It has had the cam reground. Mike
That does not sound right to me at all- have you tried a colder
spark plug? If the ring in the block is sharp that can cause it
too. Have you checked pressure with a gauge? Perhaps
you've got more compression than you think?
