pulling rules for tallmadge Ohio pull
2-banger
Can anyone tell me the rules for tallmadge pull on march 1st..i know it says in div 4 I've got to have kill switch and fenders...if I take my jd g thats got a duplex on it can I pull jackpots? If I pull a Couple classes in div 4..what can I run as far as rpms 20% over?
What you can pass tech for and get a sticker for is what you can run. Say if you are a div. 3 tractor normally you can get a div. 4 sticker with passing and then you can go to 20% in jackpots.
I was told 20% is max for tractors jumping up, the only ones running 30% would be normal div.5 tractors which not many run jackpots anyways.
