560 inner bearing for M
I am working on dad"s farmall M puller I wanted to put the 560 roller bearings in the inner axle bearing behind the bull gear. But CaseIH says they are obsolete, I have the part # it is 375215R91 but so far no one can cross it to a good number of any kind. Any help would be appreciated.
Thanks Reuben
Reuben. I have changed these bearings before. I use a sealed 6214ZZ bearing. Any bearing dealer can get this one.
(quoted from post at 15:45:57 02/04/14) I am working on dad"s farmall M puller I wanted to put the 560 roller bearings in the inner axle bearing behind the bull gear. But CaseIH says they are obsolete, I have the part # it is 375215R91 but so far no one can cross it to a good number of any kind. Any help would be appreciated.
Thanks Reuben
That is the correct number and they are still available through CaseIH but are over $300 each.
Have you used one in a IH? Noticed one with a flange on the inner race maybe like was used. But didn't see any with a special washer for the other side like IH used.
