Super .....needing specs for shifter rail slot
Anonymous-0
So last season with my stock farmall super m I was having issues in the trans where It would get in 2 gears.....today I pulled the deck plate and found 2 dent springs broke above the shift rails...also I've noticed the bottom and front and back of the shifter is wore....can someone give me a spec on the what the slot size is suppose to be on the rail...I was going to weld it and build it up along with a little work to the shifter
Your shift leaver may be wore on end and is to short letting it jump out. I have welled on the bottom end to make longer or it is easer to find one not wore.
Post this over on the farmall page and you will get the correct dimensions. It has been asked many times and I know the guys will steer you right
