Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Super .....needing specs for shifter rail slot
Super pinky
01-26-2014 17:05:25
69.49.202.4
So last season with my stock farmall super m I was having issues in the trans where It would get in 2 gears.....today I pulled the deck plate and found 2 dent springs broke above the shift rails...also I've noticed the bottom and front and back of the shifter is wore....can someone give me a spec on the what the slot size is suppose to be on the rail...I was going to weld it and build it up along with a little work to the shifter
[Reply]   [No Email]
Tim Yates
01-27-2014 20:00:39
108.4.168.81
 Re: Super .....needing specs for shifter rail slot in reply to Super pinky, 01-26-2014 17:05:25
Post this over on the farmall page and you will get the correct dimensions. It has been asked many times and I know the guys will steer you right
[Reply]  [No Email]
LCB
01-27-2014 16:12:39
69.35.208.187
Your shift leaver may be wore on end and is to short letting it jump out. I have welled on the bottom end to make longer or it is easer to find one not wore.
[Reply]  [No Email]
Super pinky
01-26-2014 17:09:21
69.49.202.4
1953 farmall super m
[Reply]  [No Email]
6 cylinder puller
01-26-2014 17:16:13
71.31.178.209
 Re: Super .....needing specs for shifter rail slot in reply to Super pinky, 01-26-2014 17:09:21
Weld,check,grind,check,grind,check,grind,check. Also check the pin in the shifter that it pivots on, they tend to wear a lot also.
[Reply]  [No Email]
Super pinky
01-26-2014 18:16:04
69.49.202.4
 Re: Super .....needing specs for shifter rail slot in reply to 6 cylinder puller, 01-26-2014 17:16:13
OK on the weld and grinding.....pin was replaced with a new one last summer
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
