TractorLinks.com
Re: mounted fuel tank on my front weight bracket today
770puller
01-26-2014 12:01:46
Ya know dboll ur kind of d***. I started visiting yt mag just to see this pulling forum since then I've become more involved I. The harvester and implement etc because there is so much negative bs on this forum . Kelly u do nice work and that is coming from one fabricator to another you could build stuff for me any day and I'm pretty picky!
baldwin racing
01-26-2014 17:29:47
 Re: mounted fuel tank on my front weight bracket today in reply to 770puller, 01-26-2014 12:01:46
770 puller,
thank you that means a lot.....this was a pretty simple idea if you look close all I did was tig weld a 3/8 nut to a 3/8 washer. I used a 3/8 bolt and screw the two nuts on with the washer in the middle....tig welded the nut to washer then backed it off......cleaned them back up and flip them over and tig welded the washer to the 7/8 chromoly. Culped the 1 inch long pieces 1/4 of an inch to 7/8 size tube, then tig welded to cross members witch are also chromoly....
Kelly
770puller
01-26-2014 17:33:03
 Re: mounted fuel tank on my front weight bracket today in reply to baldwin racing, 01-26-2014 17:29:47
Clean and simple with some nice fab work that's the way you want a tractor to look... Maybe throw in alittle bling to set er off lol
baldwin racing
01-26-2014 18:10:48
 Re: mounted fuel tank on my front weight bracket today in reply to 770puller, 01-26-2014 17:33:03
all the fab work will be painted all nice and pretty the body will stay rusty....lol jk
Kelly
