Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Digital tach for JD G
Moline G puller
01-25-2014 05:50:37
But don't u have to buy 1 for a 2 cylinder ? Or would a 4 or 6 cyl do the same thing?
north puller
01-25-2014 06:14:08
 Re: Digital tach for JD G in reply to Moline G puller, 01-25-2014 05:50:37
If you have a normal gasoline distributor, it turns at crank speed and not cam speed. It fires on compression and exhaust strokes.
Because it fires twice as often as "normal", a 4 cylinder setting is what you want.
If you have an LP distributor, it has a gear reduction to run it at cam speed, and in that case i don't know what you would use.
north puller
01-25-2014 06:58:53
 Re: Digital tach for JD G in reply to north puller, 01-25-2014 06:14:08
I bought one from denny's once. It fired from the neg side of the coil. Wouldn't work with points and copper core wires.
Copyright © 1997-2015 Yesterday's Tractor Co.
