Digital tach for JD G
Buy a snowmobile,four wheeler or jet ski tach off ebay,around $20.00 Wrap the wire around the #1 plug and follow the directions to program and you are good to go
If you have a normal gasoline distributor, it turns at crank speed and not cam speed. It fires on compression and exhaust strokes.
Because it fires twice as often as "normal", a 4 cylinder setting is what you want.
If you have an LP distributor, it has a gear reduction to run it at cam speed, and in that case i don't know what you would use.
