TractorLinks.com
Re: Gear ratios
Jeff Gravert
12-20-2013 11:11:08
By adding the tire into the equation you will need to change to MPH. The final ratio is going to tell you how many revolutions of the engine it takes to acheive one turn of the axle. You can either measure the circumference of you tire or use the loaded radius to calculate the size of tire. To calculate the mph you need to take your engine RPMs times 60 (to get from minutes to hour), take that number and divide it by your final ratio and then times it by your tires circumference. That number will be how many inches your tire will travel in an hour. The last step is to divide that number by 63,360 which is how many inches are in a mile and your answer will be the MPH. Hope this helps. Jeff
