Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
rear tire set narrow or wide?
henryrit
12-17-2013 13:17:43
198.228.200.42
my question is do you guys prefer to run your rear tire set in or out? Everyone where I pull has there rear tires set out wide except for one guy has his dished in and narrowed up and he is the tractor to beat. These are all farmall m's
[Reply]   [No Email]
Eddie Ward
12-21-2013 08:46:22
216.237.226.1
 Re: rear tire set narrow or wide? in reply to henryrit, 12-17-2013 13:17:43
The only advantage the wide setting would give you is if you are wider than the pan on the sled. Then the pan don't drag the dirt the tires dig up. Thats how I run mine and about 10 inches of each of my tires are on the outside of the pan.
[Reply]  [No Email]
Travis M
12-18-2013 09:02:48
99.155.24.139
the closer the better in my opinion
[Reply]  [No Email]
Mopower
12-18-2013 08:36:22
64.208.152.149
My 16.9X38 tires are set as narrow as I can get them and usually beat most 18.4X38 in 4&5mph classes. The tractor rarely spins one wheel and if it starts to, it adjusts quickly. Narrow is also more effective when shifting your body weight around to compensate for an inconsistent track. When most tractors are veering off in one direction, mine usually does much less, if at all. I would theorize that tires moved farther out, should one grab more, would have more leverage to swing the nose over. This has been my experience, but doesn't necessarily match what others are saying here.
[Reply]  [No Email]
Jim Johnson
12-17-2013 18:01:14
204.10.233.250
The wider the tires are set apart the more leverage one tire has over the other, so the closer they are the straighter the tractor should pull.
Jim
[Reply]  [No Email]
bberry
12-17-2013 18:00:30
108.101.49.253
Well it depends on what everyone else has. A little known secret to most pullers is finding the grooves left behind everyone elses pulls. That means if your in those grooves more tire is biting for you and less of the skid is contacting the track fo the sled. If most of your club is in go in to match the width of the groove. The power theories and axle snapping woes are minimal and unlikely at best. True the kinetic energy stored in your axle with the wheels our wide can cause fractures (if you have 300-400hp and standard instead of shaved tires), and it does take more torque to spin 38in rubber down a 8 ft long shaft as compared to 2ft. However, you talking a matter of 6inches.
[Reply]  [No Email]
RENE'
12-17-2013 16:11:31
76.22.191.162
Wide set if one wheel slips a little tractor tends to turn a little. hard to turn back without loss. RENE'
[Reply]  [No Email]
johnpop1
12-17-2013 14:39:32
96.236.54.201
I would be curious how it would affect either the axle or gearing. They will have the same load either way. It is remotely possible that one could twist off an axle but it is highly unlikely.
[Reply]  [No Email]
Lovespullin
12-17-2013 14:25:34
68.33.214.216
I set mine in, I'm not the guy to beat but top 3 usually
[Reply]  [No Email]
Harvey2
12-17-2013 14:16:59
74.138.175.233
If you pull with the wheels set out, it puts more strain on the axels and gearing.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
