TractorLinks.com
Re: Case 1175
case 1175 puller
12-14-2013 14:57:30
Don't know what all your rules are but at 5 mph you shouldn't have to do a whole lot. Maybe get a pump and injectors for a 4690. The right tire may be more important.
dboll
12-14-2013 17:48:51
 Re: Case 1175 in reply to case 1175 puller, 12-14-2013 14:57:30
if i'm not mistaken for 4690 injectors you also need 1570/2670 or 90 series heads as they are the big injectors and an 1175 has pencil tips, the big injector heads also have big valves for the 4 5/8 bore in a 504 and in the 4 3/8 bores you need to notch the sleeves to make them clear which shrouds part of the valve
case 1175 puller
12-14-2013 19:48:05
 Re: Case 1175 in reply to dboll, 12-14-2013 17:48:51
You are right about the injectors needing the different heads Doug. There are a number of diesel shops in the country that can work over the pencil injectors.
