TractorLinks.com
Re: 14.9 or 15.5 on 14 rim
north puller
12-14-2013 13:34:54
I really have no clear answer, but there is lots to consider here.
Do you have a rule that limits rim width to tire recommended size? If so, 15.5's go on a 14" rim. If you wanted to use 14.9's you'd have to narrow your rims.
If you can use any rim width you like, my personal preference is 14" or 15" for 14.9 tires, and 15" or 16" for 15.5 tires. So if you didn't want to widen your rims, go with 14.9's.
I also like the tallest tire you can run, so another vote for the 14.9's. I think that these would work well to get as close as possible to your 3 mph limit if your rpm's are limited. If you can run 20% or more rpm's, the shorter 15.5's might be the better choice to keep your revs up.
Lastly, both are a great tread for pulling, but i think the super all traction's have the edge. If there was such a thing as 14.9 super all traction, that would be the pick for sure.
Confused? :)
henryrit
12-14-2013 16:23:35
 Re: 14.9 or 15.5 on 14 rim in reply to north puller, 12-14-2013 13:34:54
there is no rim width limit and its a 10% over rpm limit. 99% of the tractors run the road and field firestones but you don't see any of the super all tractions until the 16.9's and 18.4's are allowed.
north puller
12-15-2013 09:32:43
 Re: 14.9 or 15.5 on 14 rim in reply to henryrit, 12-14-2013 16:23:35
I'd go with the 14.9 on your 14" rims. Little taller tire gives you a little more speed. Should make a nice 3 mph tractor. You should be able to blow the horn in low gear that way.
