j.d. 70 gear reduction starter
I was referred to this site to contact anyone who's familiar with gear reduction starter that will fit in a j.d. 70 w/600 ci. I can open the petcocks, it helps a little, I want to know where to get a gear reduction starter like I've seen on j.d.g's and some m farmalls. my cell is 419-796-1019 if you do starters, or know where to get one. this tractor is very competitive, and i'd like it to start better, before the original burns up.
I"ve been doing this for about 8 years. Run it on 24 volt. It works just fine. You can even get someone to build you a 24 volt charging system if you want. It"s no different than taking a old M Farmall with a 6 volt starter and putting in a 12 volt battery.
