TractorLinks.com
Re: Farmall M wheel base
D Slater
12-03-2013 18:36:52
You can find wheel base numbers listed all over the place. One reason is from a M to SM tractors part of the narrow front bolsters had a different caster angle and some list the distance for a wide front without saying its a wide front. Some must be rounded off. With the same lower bolster M and SM gas is close to 89.25 inches. MD and SMD close to 1.5 to 1.625 longer. SMTA gas or diesel close to 95.75. Wide front SMTA 99.75. They did offer a special wide for a SMTA for beet harvester use like one type used on M and SM. Don't know that wheel base but it would be a good bit longer.
EFV
12-04-2013 13:11:52
 Re: Farmall M wheel base in reply to D Slater, 12-03-2013 18:36:52
There is a factory wide front that when mounted
in the forward most position gives a 113 inch
wheelbase. It's an ugly thing,pivot point for front
end is ahead of mounting base. Steering linkage is
in front of center tube. Turning diameter is
huge,many discarded for aftermarket or later IH
wide fronts.
Pulling in Ohio
12-07-2013 12:09:53
 Re: Farmall M wheel base in reply to EFV, 12-04-2013 13:11:52
Thank you very much. Very very nice and thanks again.
