34 to 38 in. step up rims
Travis M
I need to put 38 in rims on a tractor that has 34 in. rims now. I want to keep the factory cast center. Anybody got a set of the step up rims for sale.
have some one cut you out a 3/8 weld in circle with tabs that have bolt eyes so you can run a bolt threw stock center and threw the eyes....if you under stood what I mean? look stock just be 38 inch rims and don't have to mess with wedges....
kelly
Travis- Here's how I did it on my '60 930. These rims are from a 55 series Deere, probably found on other Deeres also. The I.D. of the bolt flange fits EXACTLY over the cast centers. You just have to make 2"x2" blocks for the wedges to push against. I used 2x2 1/4 wall tubing, and welded them on. You also gotta weld on a drive lug. These rims are 16", and I have a pair of 18" to go on another tractor. Cheap and easy.
You going to Tunica?
