TractorLinks.com
Re: Ignitor 2 problems
Dodgeit
10-24-2013 09:10:21
I used their 0.6 ohm coil 45001
buickanddeere
10-24-2013 10:26:06
 Re: Ignitor 2 problems in reply to Dodgeit, 10-24-2013 09:10:21
What are the specs on that power plant you are trying to spark ?
Dodgeit
10-24-2013 10:50:54
 Re: Ignitor 2 problems in reply to buickanddeere, 10-24-2013 10:26:06
CASE 700 Gasser 267 CI CCP is 185psi running No ethanol 93 octane. Used exclusively for pulling @ 2300rpm.
buickanddeere
10-24-2013 12:33:12
 Re: Ignitor 2 problems in reply to Dodgeit, 10-24-2013 10:50:54
No need for a 0.6 ohm or even 1.5ohm coil .This engine has lots of dwell time to rebuild the magnetic field in the coil. Voltage and energy required to spark those plugs is modest too. Use a 3.0 ohm, 12V coil and spiral wound ignition wires . Autolite 216 or 3116 plugs .
Dodgeit
10-25-2013 03:36:31
 Re: Ignitor 2 problems in reply to buickanddeere, 10-24-2013 12:33:12
Thanks. 3116s are my plug of choice. Shes now sporting a 12V coil w/3.0 ohms, Spiral wound wires already on it. Now sporting a WICO DB dist. with points. Ignitor is on it's way back to Pertronix for checking.
