TractorLinks.com
Re: rotory phase converter all fired up....
mEl
10-20-2013 23:31:44
baldwin racing said: (quoted from post at 20:09:41 10/20/13) when I bought my Bridgeport series 1 j head mill I received a 5 hp rotory phase converter along with it....it was an industrial version but pull start with a rope.....my buddy and I finally took it and hooked it up to power to try out.....we installed start capacitors and a 10 sec relay....so now you just click the button and it fires right up.....this does not look like much but it runs very quiet un like a lot of others that I have herd.....now I will be able to install it in my shop and I will be able to run my Bridgeport,linley vertical mill/drill press and my south bend lathe that all run 3 phase...I only have single phase coming in my shop...
Kelly
I will mounting the start switch on my shop wall temporary I mounted on my converter box to make shure it all worked.....
That's exactly the setup I use only mine is just a standadr 5 hp motor, start caps, timer, relay and all. Only a second is all it takes for mine to fire. Works well. mEl
This post was edited by mEl at 23:33:35 10/20/13.
gtx1967jewison@yahoo.com
10-22-2013 14:18:48
 Re: rotory phase converter all fired up.... in reply to mEl, 10-20-2013 23:31:44
Jmo, but id throw all that crap in the scrap heap, install a $180 VFD (smaller than a 6-pack) & proceed to save 70% on the power bill. Old ways arent always best, just a thought.
north puller
10-22-2013 20:24:05
 Re: rotory phase converter all fired up.... in reply to gtx1967jewison@yahoo.com, 10-22-2013 14:18:48
Lots of nice features available too. Over current protection, under voltage protection, ramp start, ramp stop, coast stop, breaking, reverse, infinite speed adjustment, etc.
IF you had to go buy something, a drive is the way to go.
baldwin racing
10-22-2013 17:23:01
how are they for hp? do they drop down to 1/2 or 1/4 hp like static converters or no?
I had nothing in this converter figured what the heck....
kelly
buickanddeere
10-22-2013 18:59:35
 Re: rotory phase converter all fired up.... in reply to baldwin racing, 10-22-2013 17:23:01
57.7% of nameplate capacity
Gary Baker
10-22-2013 15:27:35
Thats how i do it. Inverter drive is the only way to go
