TractorLinks.com
Re: Oliver gurus
88 fan
10-19-2013 20:01:03
I would not exceed 3,000 rpm's with a stock flywheel. The stock flywheel is a ticking time bomb once you exceed that rpm.
If you have a good machine shop in your area, they should be able to easily make a steel one for you.
Just use the old one as a template, although if you are going to build your engine up, then you might want to install a double disc clutch. I've done all of this so if you need any info, I can help.
