TractorLinks.com
Re: Oliver gurus
kyle il
10-18-2013 05:19:40
This is great information! Thank you very much for your response. I may need to pick your brain more in the future,as I'm learning as I go about building pulling engines.
Do you know what rpm the stock flywheel will hold?
88 fan
10-19-2013 20:01:03
 Re: Oliver gurus in reply to kyle il, 10-18-2013 05:19:40
I would not exceed 3,000 rpm's with a stock flywheel. The stock flywheel is a ticking time bomb once you exceed that rpm.
If you have a good machine shop in your area, they should be able to easily make a steel one for you.
Just use the old one as a template, although if you are going to build your engine up, then you might want to install a double disc clutch. I've done all of this so if you need any info, I can help.
smokeshow
10-18-2013 07:31:57
Look into using a 310D head its crossflow It might save you money in the long run.
