Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Fuel Injecting An IH Inline Six...anyone?
buickanddeere
10-16-2013 04:47:38
What would possess you guys to want to Phart around with a distributer? Use three of those dual coil packs. The ECM calculates the spark advance and is programable.
VicS
10-16-2013 19:41:53
 Re: Fuel Injecting An IH Inline Six...anyone? in reply to buickanddeere, 10-16-2013 04:47:38
We have a tractor pulling with the Ford ecm. Just mount the 35 tooth sprocket behind your crank pulley. You are right those coil packs are neet, and really hot! Just google Ford crank triggered ign. The link will lead you to the fuel injection to go with the ign. All for about 300 dollars and a Donor 6 cyl car. You control it with your laptop, or what ever. Vic
Buzzman72
10-16-2013 07:35:08
Yeah, I know GM built a lot of engines with those coil packs. They also built a lot of Vegas, too, but that doesn't mean they were worth a damn, either. My experience with coil packs on an '88 Olds 3.8 were NOT positive. Maybe they're better NOW...but if they could get by with building junk THEN, why should I expect anything different NOW? They fooled me once; shame on them. Not sure I'd want to let them fool me twice.
High Octane
10-16-2013 08:32:16
 Re: Fuel Injecting An IH Inline Six...anyone? in reply to Buzzman72, 10-16-2013 07:35:08
thats the best part! junkyard part shopping! I think the coils from the 2.8 n 3.1 gm v6 arent that bad. bad thing was, when an injector died, it shutdown the whole engine! spent 2 weeks learning that on a 91 lumina. i drive ford for everyday vehicles. so far, just change the oil n plugs n been good to me so far. anyways, it comes down to, how to get a pickup signal from the engine, to the ecm. distributor, magnetic pickups, (crank trigger) will work either way.
Buzzman72
10-17-2013 10:42:11
 Re: Fuel Injecting An IH Inline Six...anyone? in reply to High Octane, 10-16-2013 08:32:16
Based on my prior experience with GM coil packs, I think the Ford EDIS setup sounds like the easiest conversion there...
High Octane
10-19-2013 15:54:07
 Re: Fuel Injecting An IH Inline Six...anyone? in reply to Buzzman72, 10-17-2013 10:42:11
trigger wheel can run injectors, no ecm needed in a simple form of efi. 3 injectors drilled into the cyl head at the ports, another 3 in the intake, tuned by rail pressure by adjustble regulator. crude, but it would work.
