TractorLinks.com
Re: Pumpkin Pull 2013 in the books.
Shifty Shifterton
10-07-2013 13:25:04
I thought they were 13-24's which are about 10-15 square inches LESS than 13.6 x 28 like the rules say. If anything that should be MORE legal than ANY 28 on a WC...did I hear wrong?
I also heard there is a white 36 WC with 36" spokes and no single front and a pressed steel rear end that pulled in the same class..how is this LESS wrong?
OR Did I just misunderstand the situations?
Jason Verbison
10-07-2013 15:51:47
 Re: Pumpkin Pull 2013 in the books. in reply to Shifty Shifterton, 10-07-2013 13:25:04
The facts were simply explaned from super trucker but I will qoute the rule. #12. Maximum rim width of 10 inches will be allowed in the 2600lb, 11 for the 3600lb 12 for 4600lb 13 for 5600Lb 14 for 6600lb classes. Maximum tire width for 2600=12.4, 3600=13.9, 4600=14.9, 5600=15.5, 6600=16.9.
Any questions or a copy of the full set of HMOPC rules call or email Jason Verbison 517 404 2242
Shifty Shifterton
10-07-2013 19:58:38
 Re: Pumpkin Pull 2013 in the books. in reply to Jason Verbison, 10-07-2013 15:51:47
I was under the impression that the tractor in question was running 24" rubber, which is smaller than the rule..every club I have EVER seen with a tire limit chose the tire based on square inch foot print. So you let a 13.9x36 in but not a 14.9x24?? Sounds like whoever got involved in writing your rules wrote them for themselves...oh...wait...dont that white WC run 36" spokes? Thats about the only one around..
Just repeating what Ive heard..
allaroundtractor
10-08-2013 06:12:40
 Re: Pumpkin Pull 2013 in the books. in reply to Shifty Shifterton, 10-07-2013 19:58:38
Shifty the first thing you should do before you go to pull with a different club is educate yourself on the rules if you don"t like the rules then stay home , if you show up uneducated and can"t pull go pi$$ and moan to yourself because its you stupidity. As for wc with 36 inch rubber it was not at the pumkin pull the only time that tractor has ever pulled at our club was on steel !
supertrucker2
10-08-2013 09:27:44
 Re: Pumpkin Pull 2013 in the books. in reply to allaroundtractor, 10-08-2013 06:12:40
If you people let that white tractor pull at your club Evan with steel wheels you people don't no what a stock tractor is as far as a block sheet metal and a rear end as well as a under drive in it I think you guys should have let that guy pull that had the 24 inch tires he was under the 13/6/28 rule but its your pull on the other hand what about the guy that pulled the sled out of bounds I never heard it announced during the pull only at the drivers meeting oh I forgot he was club member thats why it was never announced again so the guys that got there a little late never new that you could go out of boundswwhen hook up to the sled bad call on your club as well as the announcer oh well not my problem but I bet that guy will never pull there again as you people have said it all ended in a handshake
allaroundtractor
10-08-2013 10:58:26
 Re: Pumpkin Pull 2013 in the books. in reply to supertrucker2, 10-08-2013 09:27:44
Our club has run for 22 years just fine without the likes of you so suit your self we dont need the hassle of dealing with people like you !
allaroundtractor
10-08-2013 11:14:56
 Re: Pumpkin Pull 2013 in the books. in reply to allaroundtractor, 10-08-2013 10:58:26
Oh FYI the guy that owns the white wc left it at home and brought 2 tractors that complied with our rules !
super trucker 2
10-08-2013 13:35:41
 Re: Pumpkin Pull 2013 in the books. in reply to allaroundtractor, 10-08-2013 11:14:56
OK than so the next time you guys have a steel wheel pull are you going to let the white WC pull well if you to your club is wrong an WC never came with a under drive or overdrive so what are you going to do about that that tractor is illegal or is he a CLUB MEMBER god nows who is telling the truth you people need to check things out better GOOD DAY
allaroundtractor
10-08-2013 14:46:53
 Re: Pumpkin Pull 2013 in the books. in reply to super trucker 2, 10-08-2013 13:35:41
Nope not a member !
The white tractor is irrelevant to this past weekend , it was at our show once for steel and has not been back since , you are the one with an issue so get over it !
super trucker 2
10-13-2013 13:13:25
 Re: Pumpkin Pull 2013 in the books. in reply to allaroundtractor, 10-08-2013 14:46:53
Oh OK now I get it you and the white WC are buddies wow I no you are defending him do you two spoon togather if not maybe you should
39 A
10-13-2013 18:52:59
 Re: Pumpkin Pull 2013 in the books. in reply to super trucker 2, 10-13-2013 13:13:25
What is the problem with the white WC?
I have pulled against it before, and never noticed any reason it should not pull.
super trucker 2
10-14-2013 03:29:54
 Re: Pumpkin Pull 2013 in the books. in reply to 39 A, 10-13-2013 18:52:59
For one thing you are dumber than what I thought you was it does not have a stock block it has a under drive in it that was never offered from the factory it was an dealer option it does not have the correct front end under it to have 36 inch tires it has to have a single front wheel in 1937 they never had a steel rear ends in a WC but I no that you are going to say its a replacement part . If you can't look at that tractor and see what's wrong with it than everyone needs their eyes check
39 A
10-14-2013 04:23:21
 Re: Pumpkin Pull 2013 in the books. in reply to super trucker 2, 10-14-2013 03:29:54
So are all the tractors that pull with Hudson Mills totally stock?
st 2
10-14-2013 07:05:20
 Re: Pumpkin Pull 2013 in the books. in reply to 39 A, 10-14-2013 04:23:21
No but I think you need to mind your business this doesn't concern you you just go do your thing
39 A
10-14-2013 18:21:23
 Re: Pumpkin Pull 2013 in the books. in reply to st 2, 10-14-2013 07:05:20
I pull with the Hudson Mills club a lot, and am a member there also, not sure why you are trying to stir up trouble.
allaroundtractor
10-14-2013 17:26:05
You must be a real idiot as I stated before the wc in question was at our show once and has not been back , as for the member comment the owner of the wc is not member. I however have been a member for 20 years , of course if you understood what you read I would not have to tell you that. If you don't like our pull don't come back , in fact I just think you pi $$ed you got you butt handed to you by some tractors that are closer to stock than yours . So you need to put on you big boy panties and except it !
allaroundtractor
10-14-2013 18:31:15
 Re: Pumpkin Pull 2013 in the books. in reply to allaroundtractor, 10-14-2013 17:26:05
Thanks 39 A !
arcticcat120
10-17-2013 11:45:47
 Re: Pumpkin Pull 2013 in the books. in reply to allaroundtractor, 10-14-2013 18:31:15
Hello To whom it may concern I'm the individual that had the issue with the tires at the pumpkin pull. To get things straight it was a misunderstanding between myself and the club the member who told me that I was good to pull on that day but I wasn't we have north learned a lesson since then we have manned up to each other said we were sorry and went on our way we have no problems unlike some of you people who keep on beating a dead horse you people need to mind your own business Its old Grow Up move on as I read some of the post laugh and as far as what person brought what tractor I DON'T care what you brung i go out and have fun so all of you people who think Its me about saying something about that WC you people can kiss my .... where the sun doesn't shine and you more who you are... thanks. Dave
