TractorLinks.com
fuel prices
Eric Bloom
10-05-2013 08:16:25
well finally ran through the barrel of 110 that I got 3 years ago.
im experiencing sticker shock now. cheapest I have found is 7.50/gal for 55 gal drum.
wondering if e-85 will work in a 11.5-1 motor with 280 cranking pressure.
thanks
Eric
buickanddeere
10-09-2013 06:55:45
 Re: fuel prices in reply to Eric Bloom, 10-05-2013 08:16:25
280psi cranking pressure is beyond the point of diminishing returns. That engine needs more cam to increase the amount of air/fuel mixture through the engine.
bock
10-09-2013 06:14:17
i run e85 in wc for as long as i have been pulling it, no bad efects, so far, will eat sediment bowl gasket up, hasnt hurt anything else , need to drill power jet out quite a bit to get to run right,
LCB
10-07-2013 09:04:53
That is for a barrel and I figure it at 50 gal so that might be wrong price per gal.
LCB
10-07-2013 09:01:12
The place is Performance Motor Sports 618 664 4767.
LCB
10-07-2013 08:58:47
Well you found it cheaper then I did. They are at 438 plus taxes which according to my figures is 8.76 per gal. How come your not coming to Boonville afraid of my H? We are coming Fri because Judy wants to go through fleas. I can bring one if you are going to be around Fri.
LCB
10-05-2013 15:25:32
Do you want me to check prices here. I am planning on come to Boonville this comeing week end. Leroy PS I have went trough 3 barrels since then.
Eric Bloom
10-06-2013 15:51:52
 Re: fuel prices in reply to LCB, 10-05-2013 15:25:32
that would be great Leroy. or send me the number of the place you get it from.
I won't be at Boonville, we are not putting that pull on. I will be in odin visiting mom.
Thanks
Eric
patrickmull
10-05-2013 08:47:54
I go to the airport and get mine 5.35 per gal
dboll
10-05-2013 13:09:03
 Re: fuel prices in reply to patrickmull, 10-05-2013 08:47:54
airports don't sell 110 race gas, most generally they sell 100LL, there is a difference between the two
RICHB
10-05-2013 08:29:58
I have heard good and bad on E85...its harsh on components from what I hear.I have a 88 thats 250psi static...I mix c12 and super unleaded and am happy with the results...C12 is right about 12 a gallon here.
