m farmall engine question.
crl800
I see a lot of m farmalls pulling. Thought about building one to get down to lighter classes. Would you guys use piston or lp head to gain some power?
The LP head is a good investment that will still be there when you decide you need to go bigger.... where the pistons will need to find a new home when you go bigger :)
yes go with a lp head very good investment....for the same money as stock valves get oversized valves installed in it as well then the head work will be done other than porting in future.......
kelly
