Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: What size tires with 200 hp
Goldsburg
09-27-2013 06:43:48
Vic -
He may not have, but I have...
Bigger is NOT ALWAYS better. It definitely depends on track conditions. As stated previously, matching your ground pressure to the "ideal" ground pressure of the track is where the win resides!
I agree with the philosphy of doing whatever it takes to get most out of your tractor. However, I prefer running 4th gear with slightly smaller tires than running 3rd gear with slightly bigger tires. In MOST cases, the momentum will override the marginally higher traction...
Regards,
Goldsburg
778899m
09-28-2013 10:20:46
 Re: What size tires with 200 hp in reply to Goldsburg, 09-27-2013 06:43:48
Goldsburg,I do have and am glad others see it as it actually is,small trumps large many times.So many different scenarios in all motor sports,driver choices,track reading ability all matter more than tire size.Power does no good if it isn't hooked up,speed is hard to control with out proper balance,ect.Larger tires alone hurt more guys in my classes than helps them,granted,sometimes,larger is better.
778899m
09-27-2013 16:32:25
To Vic,my history and winning record all over the country,in many classes speaks for itself,for almost thirty yrs. Smaller tires win many times over the largest allowed,mostly in smaller weight divisions.Most on here are small time antique pullers,BIG POWER,BIG POCKET BOOKS are a whole different story,when you have 200-three thousand hp,it takes as big as you are allowed,but not for some putt - putt.Every dog has it's day.Every tire and every tractor can and has won on a given day and track.
