FRT WT FOR FARMALL M
Its not an M but the way I made my front bracket for my H is get 3 or 4" angle iron and cut them into 20" or so lengths. Drill two holes in them and bolt them onto the front of the tractor. You will need to notch them as you want the L to face inward. Then cut a section of your angle iron to fit in between them to connect them together. That L will face toward the front of the tractor. That is where you would want to hang suitcase weights. With the "L" facing inward on all 3 pieces, you create somewhat of a cradle and you can stack blocks of concrete in there as weights and put all your suitcase weights on the back.
text me 315-705-5735
I built this is for my pullen m....
pic 1 its just sitting on my neighbors m
pic 2 its all complete other than paint
kelly
one of my best friend cut it on a lazar cnc table....I gave him all the measurements and he cut everything out for me on his own time after work...its all 1/4 steel and is all flat plate.....I welded the braces in my self, not angle I use big 90 magnet squares...to hold it I tig the top plate (Farmall)and bottom brace in which now has 7/8 holes in it every 2 inches to help lighten it up (can not see in pic)and everything elese is mig welded...
thanks Kelly
here a pic of the braces when cut out....I bored the 7/8 holes in the bottom plate my self...
(quoted from post at 12:30:32 09/16/13) Its not an M but the way I made my front bracket for my H is get 3 or 4" angle iron and cut them into 20" or so lengths. Drill two holes in them and bolt them onto the front of the tractor. You will need to notch them as you want the L to face inward. Then cut a section of your angle iron to fit in between them to connect them together. That L will face toward the front of the tractor. That is where you would want to hang suitcase weights. With the "L" facing inward on all 3 pieces, you create somewhat of a cradle and you can stack blocks of concrete in there as weights and put all your suitcase weights on the back.
I see Cliff there on his 720 pulling back. I can see that the track is neither Williamsburg nor Westfield, Is it Blandford?
Yes that was Blandford. Turnout was good, 20 tractors I think. Got 3 inches of rain the night before and more during the day so my tractor didnt do well in mud. Doesnt look too muddy in the picture but it was. Camped the night before, that was cool.
I believe thats his John Deere R.
