Yesterday's Tractor Co.
Shop Now View Cart
09-16-2013 12:30:32
Its not an M but the way I made my front bracket for my H is get 3 or 4" angle iron and cut them into 20" or so lengths. Drill two holes in them and bolt them onto the front of the tractor. You will need to notch them as you want the L to face inward. Then cut a section of your angle iron to fit in between them to connect them together. That L will face toward the front of the tractor. That is where you would want to hang suitcase weights. With the "L" facing inward on all 3 pieces, you create somewhat of a cradle and you can stack blocks of concrete in there as weights and put all your suitcase weights on the back.
09-18-2013 18:44:20
 Re: FRT WT FOR FARMALL M in reply to PretendFarmer, 09-16-2013 12:30:32
I see Cliff there on his 720 pulling back. I can see that the track is neither Williamsburg nor Westfield, Is it Blandford?
