TractorLinks.com
Re: john deere g
ericsegaline
09-12-2013 23:46:58
power block pistons are taperd at the top are you cutting the hole top of the piston or just putting a taper on the edge like a power block piston
2-banger
09-13-2013 07:42:52
 Re: john deere g in reply to ericsegaline, 09-12-2013 23:46:58
i had edge on piston cut with a taper like it was.getting close to top ring thou...i thought about block spacer..iam afraid it will draw too much attention..iam not sure if top ring gets as high as plug i will check that out tonight
clampdaddy
09-13-2013 11:19:22
 Re: john deere g in reply to 2-banger, 09-13-2013 07:42:52
Quoting Removed, click Modern View to seeIf the ring is still below the spark plug at tdc you should have a lot of meat to work with, if the ring passes the plug hole the you have other problems to worry about.
