TractorLinks.com
Re: The first 1st place this year
Buckeye Oliver collector
08-30-2013 00:12:55
Looks like a dead weight sled. An H set like that would have a h#ll of a time moving a transfer sled in a 6500 class.
M.Genrich
09-01-2013 09:56:44
 Re: The first 1st place this year in reply to Buckeye Oliver collector, 08-30-2013 00:12:55
my thoughts exactly. Im not trying to be a smart a-- but how does dead weight pulling work? It seems to me your pulling the same amount of weight at the ten foot mark as you are at the two hundred foot mark. Is it dirt in front of the pan that stops you? Is the challenge to find a better place to run on the track or who can find the best rubber or drawbar set up? Weight transfer sleds make the tractor work a little harder all the way down the track and tests the tractor output as well as the driver and set up. No disrespect intended, someone please explain.
showcrop
09-01-2013 11:49:18
 Re: The first 1st place this year in reply to M.Genrich, 09-01-2013 09:56:44
I pull sled mostly but I just LOVE a stone boat pull occasionally. There is quite a lot of difference and it is more technical. In sled pulling you need to just keep the sled moving. In a stone boat pull, before you can keep it moving you have to get it started. On the final round of the weight class when most competitors cannot get a full pull, which is usually 10-20 feet, It takes very good technique to get it to start moving. It takes some clutch slipping and just the right amount of throttle and just the right amount of front end lift. The amount of draft you get from the boat varies a lot because the length of the chain varies a lot. I have seen any where from 4 to 12 feet. Most would say that momentum would not play a part because the speed is so slow. With my 960 I pull in second quite a bit. (Yeah, I know to Pretend Farmer that would be "Speed Pulling"). Last fall at one pull I read the track as telling me that momentum was going to decide it. I usually will use 2nd gear only in the first 2-3 rounds when the boat is lighter. I used it in each round in both the 3500 and 4000 lb classes, and won both classes, with 9 in the 3500 and 12 in the 4000, including 4 Super Cs in the 3500 and three in the 4000 lb. classes. I pulled 8500 in 3500 and 10,000 in the 4000. Give it a try some time you may like it! Another good thing about stoneboat pulling is that it is generally believed that extra power will only hurt you in stoneboat pulling, whereas it is generally believed that to win in stock sled pulling you have to cheat, so it tends to make people stop and think. Ford Power!!
