TractorLinks.com
Re: Spark plugs for Oliver
Dick W.
08-26-2013 18:24:19
Maybe you just need more cam to cut the low speed cylinder pressure. Also set the timing back 5 degrees and then run it and see if that helped.
mEl
08-26-2013 19:23:21
 Re: Spark plugs for Oliver in reply to Dick W., 08-26-2013 18:24:19
That's a lot of static compression, I,d be inclined to try a bit higher octane fuel.
SPT
08-27-2013 06:14:03
 Re: Spark plugs for Oliver in reply to mEl, 08-26-2013 19:23:21
Thanks for all the suggestions, it has been running great for about 4 years and all of a sudden issues, will check out ignition system this AM to insure that I am getting proper fire..
dblair
08-27-2013 13:26:24
 Re: Spark plugs for Oliver in reply to SPT, 08-27-2013 06:14:03
I'd listen to Mel
SPT
08-28-2013 06:33:00
 Re: Spark plugs for Oliver in reply to dblair, 08-27-2013 13:26:24
Thanks again, discovered it was nothing more than a back break-a-way switch, knew it had to be something simple.
