Thanks for info on tire pressure
D beatty
Went to a pull this weekend with Farmall 450 and set the tire pressure at 14 lbs. Had to check pressure several during day because it got so hot and pressure went up 2 lbs. in a half hour. The old girl didn't do to bad for second time out pulling. In the 6500-7000 took second place. In 5000-10000 took a fourth place and in the 7000-7500 took fifth or last place this was the smallest class of the day . Thanks for your help and suggestions.
