Yesterday's Tractor Co.
Shop Now View Cart
Re: HEI dist
08-07-2013 16:13:56
Quoting Removed, click Modern View to see I recomend you using the newer computer controlled hei distributor . It has no mechanical advance . You have to change the 8 pin module out to the four pin if your not planning on running a msd box. Then its pretty much just removing the hei gear and adding your tractors old delco remmy point distributors gear onto the hei . Your timming will be locked unless you run a advance or retard module on the msd box. Most set their timing total timing and lockout the advance anyway so your hei has already done that if you choose the computer controlled hei distributor
