pressed steel wheels
I'm looking for steel wheels for my Super C, 13-6, 36 is what I have for a tire. I can't seem to find 36's that wide. Or can I just buy the center and a hub. The only place I've found is Miller's in Ohio but according to their website they don't have what I need. Any direction would be appreciated.
Most 2010 john deere row crops had 13.9x36 tires on 9 bolt pressed steel rims. Prob be a 12 inch wide rim if that would help you any.
be some work but if you had a mig welder,zip cut wheels for grinder...mark them and number lines so you know its lined back up... you could cut them in half then weld in 2,4 inches to widen them weld other side back on just takes time.....and make shure there the same width measurement when tack in place....then weld in solid...
kelly
Deere rims, and the early oliver 70 tractors on pressed steel had a rim with a deep drop and a smaller pressed steel center.
