TractorLinks.com
Re: Alumnium Radiator - M
Superih
07-23-2013 08:54:28
Kelly,
Have you ran your set up on a hot day? The problem we have ran into trying to use a car radiator is that the core is not big enough to provide sufficient cooling, I'm assuming that is what you used being it only weights 18 lbs. If I recall you are running a fairly stock engine so it may keep up.
These radiators should keep up with 500 cubes no problem.
baldwin racing
07-23-2013 18:37:12
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 08:54:28
I am not running any stock parts....water parts.....electric fan with a shroud to pull air through,electric water pump, and a temp relay to kick it on when it gets warm....I will not be peradeing it around.if you know what I mean..start up pull and shut off like dry blocks when my big motor is done...
Kelly
tractor will be a antique hot stock class when done......
but if it runs warm I know where there are alum full size ones. that fit right in....lol
S.D.L.
07-23-2013 11:18:16
Your not doing any for an Oliver are you? I, as well as others, would be interested in some for the Olivers.
Superih
07-23-2013 11:27:11
 Re: Alumnium Radiator - M in reply to S.D.L., 07-23-2013 11:18:16
Not yet.
m manley
07-23-2013 21:01:49
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 11:27:11
luke you can count me in one of those let me know?
