TractorLinks.com
Re: Alumnium Radiator - M
baldwin racing
07-23-2013 07:13:52
i just bought a griffin allum rad 18x22 for $250 and made a chromoly light weight rad bracket with 1/4 turn fastners to hold on nose peice....and hood latches to clip to....but had to do all the measuring and figuring off stock rad.mine wieghs 18 lbs with bracket....but nice to see a complete replacement to fit in with no mods....
kelly
Superih
07-23-2013 08:54:28
 Re: Alumnium Radiator - M in reply to baldwin racing, 07-23-2013 07:13:52
Kelly,
Have you ran your set up on a hot day? The problem we have ran into trying to use a car radiator is that the core is not big enough to provide sufficient cooling, I'm assuming that is what you used being it only weights 18 lbs. If I recall you are running a fairly stock engine so it may keep up.
These radiators should keep up with 500 cubes no problem.
baldwin racing
07-23-2013 18:37:12
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 08:54:28
I am not running any stock parts....water parts.....electric fan with a shroud to pull air through,electric water pump, and a temp relay to kick it on when it gets warm....I will not be peradeing it around.if you know what I mean..start up pull and shut off like dry blocks when my big motor is done...
Kelly
tractor will be a antique hot stock class when done......
but if it runs warm I know where there are alum full size ones. that fit right in....lol
S.D.L.
07-23-2013 11:18:16
Your not doing any for an Oliver are you? I, as well as others, would be interested in some for the Olivers.
Superih
07-23-2013 11:27:11
 Re: Alumnium Radiator - M in reply to S.D.L., 07-23-2013 11:18:16
Not yet.
m manley
07-23-2013 21:01:49
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 11:27:11
luke you can count me in one of those let me know?
