TractorLinks.com
Re: Alumnium Radiator - M
Superih
07-23-2013 06:50:00
I"m currently developing this radiator. It is designed to be a drop in replacement, everything bolts in place, it weights 30 lbs less than a stock radiator and holds less water with 25% better cooling capacity, should loose around 40 lbs total when complete. Hopefully I"ll install this in the next couple weeks to verify everything fits right.
This kit will be available with all hoses and hardware necessary to install. Looks like the pricetag will be around $600.
2276
09-26-2013 09:12:18
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 06:50:00
hows the alum. rad. progress? you getting close to marketing them?
Superih
09-27-2013 04:56:53
 Re: Alumnium Radiator - M in reply to 2276, 09-26-2013 09:12:18
My M has been on the road all summer, just got it home last weekend and pulled it into the shop last night.
I will be installing next week, but everything looks promising.
6pack
07-25-2013 17:22:36
mshultz
07-23-2013 18:18:31
That looks like a nice unit. Keep us posted! Thanks!
Cliff S
07-24-2013 19:48:40
 Re: Alumnium Radiator - M in reply to mshultz, 07-23-2013 18:18:31
Is there a possibly of a H radiator in the future?
Cliff S
Superih
07-24-2013 20:53:21
 Re: Alumnium Radiator - M in reply to Cliff S, 07-24-2013 19:48:40
Depends on how much time I have, if there is enough demand I could put the time into it, the thing is I don't pull an H I pull an M so I don't need one Lol!
Justin Monroe
07-25-2013 17:16:47
 Re: Alumnium Radiator - M in reply to Superih, 07-24-2013 20:53:21
Just do it. You can use mine for the template! Lol
Superih
07-25-2013 21:39:21
 Re: Alumnium Radiator - M in reply to Justin Monroe, 07-25-2013 17:16:47
I know you don't need it, you actually have to run your tractor to require a radiator! Lol
Justin Monroe
07-26-2013 18:40:21
 Re: Alumnium Radiator - M in reply to Superih, 07-25-2013 21:39:21
That's why you can use it for a template!
2276
07-23-2013 09:00:27
superih i would like to purchase 1 or 2 of those radiators when they become available. how do i get ahold of you
Superih
07-23-2013 09:59:09
 Re: Alumnium Radiator - M in reply to 2276, 07-23-2013 09:00:27
I will post them for sale on here, my email is superih@hotmail.com, phone is 9eight9-2eight0-3eight69.
Again these are not ready yet, I want to make sure everything is perfect before taking orders.
2276
07-26-2013 12:09:39
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 09:59:09
superih do you have any idea about when these radiators may be avalible thanks
Superih
07-26-2013 12:35:11
 Re: Alumnium Radiator - M in reply to 2276, 07-26-2013 12:09:39
Probably september/october
north puller
07-23-2013 08:32:36
Want to send me an email? I'd like to keep in touch. Let me know when your ready to start selling them.
Superih
07-23-2013 08:56:11
 Re: Alumnium Radiator - M in reply to north puller, 07-23-2013 08:32:36
email sent.
baldwin racing
07-23-2013 07:13:52
i just bought a griffin allum rad 18x22 for $250 and made a chromoly light weight rad bracket with 1/4 turn fastners to hold on nose peice....and hood latches to clip to....but had to do all the measuring and figuring off stock rad.mine wieghs 18 lbs with bracket....but nice to see a complete replacement to fit in with no mods....
kelly
Superih
07-23-2013 08:54:28
 Re: Alumnium Radiator - M in reply to baldwin racing, 07-23-2013 07:13:52
Kelly,
Have you ran your set up on a hot day? The problem we have ran into trying to use a car radiator is that the core is not big enough to provide sufficient cooling, I'm assuming that is what you used being it only weights 18 lbs. If I recall you are running a fairly stock engine so it may keep up.
These radiators should keep up with 500 cubes no problem.
baldwin racing
07-23-2013 18:37:12
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 08:54:28
I am not running any stock parts....water parts.....electric fan with a shroud to pull air through,electric water pump, and a temp relay to kick it on when it gets warm....I will not be peradeing it around.if you know what I mean..start up pull and shut off like dry blocks when my big motor is done...
Kelly
tractor will be a antique hot stock class when done......
but if it runs warm I know where there are alum full size ones. that fit right in....lol
S.D.L.
07-23-2013 11:18:16
Your not doing any for an Oliver are you? I, as well as others, would be interested in some for the Olivers.
Superih
07-23-2013 11:27:11
 Re: Alumnium Radiator - M in reply to S.D.L., 07-23-2013 11:18:16
Not yet.
m manley
07-23-2013 21:01:49
 Re: Alumnium Radiator - M in reply to Superih, 07-23-2013 11:27:11
luke you can count me in one of those let me know?
