(quoted from post at 16:48:51 07/22/13) Any sources for them? Do they really cool better than the originals? Ours needs one from a 450, which holds about a gallon more liquid to keep cool.
Thanks!
(quoted from post at 07:13:52 07/23/13) i just bought a griffin allum rad 18x22 for $250 and made a chromoly light weight rad bracket with 1/4 turn fastners to hold on nose peice....and hood latches to clip to....but had to do all the measuring and figuring off stock rad.mine wieghs 18 lbs with bracket....but nice to see a complete replacement to fit in with no mods....
kelly
(quoted from post at 08:32:36 07/23/13) Want to send me an email? I'd like to keep in touch. Let me
know when your ready to start selling them.
(quoted from post at 09:00:27 07/23/13) superih i would like to purchase 1 or 2 of those radiators when they become available. how do i get ahold of you
(quoted from post at 11:18:16 07/23/13) Your not doing any for an Oliver are you? I, as well as others, would be interested in some for the Olivers.
(quoted from post at 19:48:40 07/24/13) Is there a possibly of a H radiator in the future?
Cliff S
(quoted from post at 09:50:00 07/23/13)(quoted from post at 16:48:51 07/22/13) Any sources for them? Do they really cool better than the originals? Ours needs one from a 450, which holds about a gallon more liquid to keep cool.
Thanks!
I"m currently developing this radiator. It is designed to be a drop in replacement, everything bolts in place, it weights 30 lbs less than a stock radiator and holds less water with 25% better cooling capacity, should loose around 40 lbs total when complete. Hopefully I"ll install this in the next couple weeks to verify everything fits right.
Those look really nice!!! Luke
This kit will be available with all hoses and hardware necessary to install. Looks like the pricetag will be around $600.
(quoted from post at 17:16:47 07/25/13) Just do it. You can use mine for the template! Lol
(quoted from post at 12:09:39 07/26/13) superih do you have any idea about when these radiators may be avalible thanks
(quoted from post at 09:12:18 09/26/13) hows the alum. rad. progress? you getting close to marketing them?
(quoted from post at 19:59:35 11/23/13) Any update on these?
