oliver 88 weight
kendalinmn
New User
How much does a gas 88 weigh? No fluid, cast center rear wheels, 15.5x38, still has the belt pulley and hydraulics. Thanks
I have a couple of these.....going to weight in right at 5200 without a driver. Of course this depends on how much oil is in the rear end, & gas in the tank.
Either put pressed steel on the back instead of cast or pull the hydraulics and belt pulley out. I have a S88 with pressed steel no hydro no belt pulley and it weighs 4000 empty
you shouldn't have any problem getting to that weight with tin wheels. Nebraska test with a 200 lb. driver weighs 5285 .
I've been having a hard time finding pressed steel wheels, I'll just have to keep looking. Any idea how much weight I can drop by taking the heavy front hubs off?
I think you will make 5000 if you drop 2 of the following; heavy front hubs, hyd, belt pulley or pto shaft and housing. I'm at 6000 with 3 sets of weights, and everything but the hyd
I weighed them at one time but forget. I think if you swap light hubs for heavy you will lose 50-60lbs. Call korves and get a flat top cover and a belt pulley eliminator kit. In a couple hours you will have your weight problem solved
