Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Help with JD G
Earl-IL
07-22-2013 12:13:01
Things to look for. Gas cap not vented, restriction in sediment bowl, carb. not clean or restricted at needle & seat. Timing off. Set timing 25 deg. total advance. You have to get rid of that hot manifold. You need to read your plugs as to color. They have charts in back of spark plug books. High comp. you need a colder plug. High compression needs the best ignition you can get. With engines running 11-1 comp. ratio I have been able to fire the plugs with a Wico mag. Rebuilt perfect cond. Special HD coil. NO resistor plug wires Wire type plug wires soldered at both ends.
