Heavy Duty Field and Road Tires
Mopower
I picked up some "Heavy Duty Field & Road" 15.5X38 Firestone tires. They are nearly full tread, hard as a rock (with moss growing on them), and extremely light weight. The bar has a bit if a squared off tip on it. The tread needs cutting because the edges are a little rounded from wear. Has anyone used this style of tire? Cut them? Results? Thanks.
So the "heavy duty" tires are really light? I have a set of these on my 880 that I just bought. Figured they would weigh more since they say heavy duty on them. You weigh one of them by chance?
Used them for several years on a 88 and they worked great. have since quit pulling the tractor and would probably sell them if anyone is interested. they are full cut and on rims and are in southwestern IN.
Pull some top cut didja? I see there's quite a radius up to the bar. Justin said they'd be better full cut. But there goes top cut class. maybe an agressive angle would be better.
