TractorLinks.com
Re: John Deere 70
buickanddeere
07-10-2013 07:19:27
Too much mechanical compression and/or too short of cam duration. Compression pressure does not directly equal HP. If more , more and more compression pressure improved the Brayton Cycle heat engine. Why are not diesels running 30 to 1 compression? Torque on the crank is the difference between compression pressure and combustion pressure. Higher compression pressure without gaining a corresponding greater amount of combustion pressure does not equal more torque. Working or effective pressure is a function of heat and pressure. In short. Odds are that tractor would make more power with more cam to let it breath.
