TractorLinks.com
Re: JD A Engine Rebuild
Noforddon
07-03-2013 06:34:31
Do you think I should go ahead an remove eyebrows now before assembly? And will it be a performance advantage? Keep in mind it's LP.
buickanddeere
07-03-2013 07:16:19
 Re: JD A Engine Rebuild in reply to Noforddon, 07-03-2013 06:34:31
We have yet to hear about cam duration. Mechanical compression ratio alone doesn't mean d!ck all . Did the piston manufacture communicate with the cam grinder and have the components match? Even with LP this would be the time to mill the eyebrows off. The eyebrows were only there on Cyclone heads to add swirl to the mixture to keep the air/fuel mixture mixed. Not required or even wanted with vapour fuel. As shown on the head cutaway. That other shrouded area around the intake valve should also be cut out to piston bore dia. This would have been the time to install over size valves too.
