OTTPA Pull in Denton N.C. July 4th
Anonymous-0
Is anyone planning on attending the Pull in Denton N.C. on the 4th? I would like to pull there but it is a 4 hour drive and I know there will be lots of rain between now and then. Does the track there drain well? Has anyone here pulled with this group before and how did you like it? Any and all comments on this track and group are deeply appreciated.
Thanks,
C.Elliott
Thanks Molinesam,
What are you pulling and what classes? I take it you are pulling a Moline of some sort.
C.Elliott
Massey 444, I have it set up for 4500-6500 lb. classes. It does well in the 6-8 mph classes. I guess I will have to run in the 5 mph classes because the 7.5 mph classes are 4200 and 6200. I can't make 4200 and 6200 @ 7.5 mph may be a little too much to ask of the old 444. Can your M make 12 mph @ 6500 lb.? If it does that is one bad M!
C.Elliot
The 5 mph classes are popular & competitive. My co-pilot is only 14 so we"re locked in 5500/6500# 5 mph per age restriction. The scales are usually 200# light so 4200 may not be outa" reach for you.
If my numbers are right, 1st in 4000B, tied for 2nd in 4500B, and 2nd in 5000B. I just need a little more power before Lexington the 20th.
the track is in a pit , usually hot as h$!! , and let me know if you pull it over 150 ft . they set it tight . I was never real happy with a tight sled .
have a great time Denton is always fun .
