Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: dieseling????
Gary Baker
07-01-2013 17:32:02
Ignition timming has nothing to do with dieseling. Ignition is turned off, so cant be timming. What compression ratio are you running? When shutting off engine you should be at a complete idel. Sounds like you need better fuel
baldwin racing
07-05-2013 08:18:21
 Re: dieseling???? in reply to Gary Baker, 07-01-2013 17:32:02
just because you buying 110 fuel look at the label look at the true motor octane, not what pump octane is.....go higher octane may fix problem......like gary mention....
mlpankey
07-01-2013 18:15:49
garry is right ignition isnt problem but plugs heat range could be . try a plug two steps colder than what you run now
