Grader water tank
John 37A
At our last pull, it got a little dusty in the late afternoon. I am wanting to it a water tank on one of our graders to help with this issue. How do you guys do it? Any pictures?
John 37A Go back to Inola, Okla Thanks - Topsarg 05:17:19 06/23/13 Ronnie has one mounted to his and nurse tanks on another trailer so he can fill it in just a coupla minutes. Could change nozzle size to add more or less water. Lynn
John 37A Found another view. He got a little carried away with the water though. Lynn
http://greencountrytractorclub.com/Porter.html
Larry Stephens has the neatest
grader/roller/waterer. He has a D17 tricycle, with
a front mount cultivator frame with the V blade
and rear smother blade mounted to it. Then pulls a
roller behind the tractor, and on top of the
roller is a 300 gal tank. Then he has two 12 volt
sprayer pumps with 2 sprayer tips to each pump
(probably just 2 gal a minute pumps). Then has a
foot switch so you can spray when you want. I
drove it for about 1/3 of a event and I sprayed
water every pass and the tank lasted for 75 hooks
or more.
HERE ARE THE TWO I HAVE ,ONE WITH WATER,ONE NOT
