JohnDeereJimOhio
We pulled head and cleaned it up it had a crack between the valves.. Looks like at some point it was cracked ad filled with stop leak.. I"m assuming since I drained the water out while I worked on it the stop leak shrunk and then allowed it to leak.. I think this cracked worse on the inside and is letting water in the exhaust valve as there was visible rust down in the chamber.. Hopefully have a new head this week and get it milled and a valve job and throw it back together.. Not gettin much pullin done..
I had 2 that looked just like that. Ended up having one of them welded up. Few things are more frustrating than having your tractor apart during pulling season.
