Centrifugal spun-cast iron or poured cast iron sleeves?
S.D.L.
Assuming most stock and stock replacement sleeves are made of cast iron, are the sleeves in a JD 4020 and an Oliver 1855 centrifugal spun-cast iron or poured cast iron? Just curious, thanks!
S.D.L I would take a look at power bore sleeves. they have many in stock sizes available in ductile iron. if you are building a Waukesha a 4020 sleeve will require considerable machining to fit. straight sleeves in ductile iron are around $ 60.00 apiece. build it rite the first time you wont regret it. good luck enjoy your build. doug
