Super M hanging up in 2gears
Anonymous-0
So my farm all has a issuse and at times in the trans its gets caught in 2 gears.......I just have to pop the cover on the top off reach in and tap on the 1st gear to the front and the 2nd gear from the front they seem to get hung up ......what could be the problem......shifter lever or is it the rails in side the trans......any ideas
well this is a very common thing on a lot of these farmalls and international's, due to the gear shift lever getting worn in the shift rails. need to build the end up. also to get gears back in nuetral, just remove gear shift lever and line up the rails with a cat bar or big screw driver. dont need to pull any trans tops.
So when I go to weld on the end of the shiffter to build it up I take it I need toe weld front and back and not the sides or bottom correct
