JohnDeereJimOhio
Well yesterday I pulled the valve cover and then rocker arm assembly. The tractor had been warmed up and then we re-torqued the head. Once assembling the rocker arm assembly I had the plugs out and cranked over the motor. On the number two cylinder it was chugging out water.. So that shot down the plans for a tractor pull this weekend. I pulled the rocker arm and everything off and ended up pulling the head. On the head gasket there was no noticeable damage. In number two there was a lot of water. So from what u guys have responded the head between the valves seems to be the weak spot. I need to get it magna fluxed first and see whats going on. It was loosing a lot of water so im hoping it the head and not the block. I found a good head and Im tempted to get it and throw everything back together but Idk.. Any thoughts?
