farmall 560 grabby brake
bard
The left brake on my 560 is fairly grabby and not very smooth at all. I took it apartand everything looked fine other than dirty. I cleaned everything up very well but no difference. Anybody got an idea why its so grabby. Thanks
Check and see if there is a rough spot or worn ridge where the plates hold on the drum, they need to slide on those tabs freely, grind smooth
I'm not familiar with the 560 brakes but my oliver gets real grabby when they get a little gear lube on them as my seals leak slightly. A little brake clean on the parts once a year and they work good again.
we sandblast the break pads and drums to make them more rough and to get rid of the rust.works everytime. make suretheballs are nice and smooth other wise they stick and act like you have the break adjusted to tight.
